the strong parts???
shonum
NW ohio
i have a 94 mtx and i am in the middle of rebuilding it due to a bad rod bearing. so i was wondering because i have read that the 3.2 has forged parts that the mtx dosent have forged so i want to know a list of the stronger parts and from which engine so i can build my engine a little stronger please write me back thanks!!!!
Sho Amo
SmkTyresntDrugs
Olney, Md
the rods and wrist pins are slightly larger/stronger in the 3.2 but both are forged. there are alot of boosted guys making lots of power on the 3.0 parts.
gmail
Well-Known Member
sunbury pa
the block is tougher also it has extra webbing and is slightly thicker.
not that the block needs to be stronger tho
shonum
NW ohio
ok so there is nothing i should get from a 3.2 to put into my 3.0
gmail
Well-Known Member
sunbury pa
not unless you wanna have .2 more liters
if you want to go 3.0 dont take anything from the 3.2 its not needed.
SHO_DOODmorrris
Owner & Fanatic
Alberta
oil pump flows more on a 3.2 slight modification to teh timing cover is required i belive.
AREA 91
PA SHO SHOP
Area 91
Yes you can swap the 3.2 pump onto a 3.0 block.
Many have done it.
poffffd
