The Official SHO 1/4 times thread! (Current as of 7/29/15)
steve142857
11's in '12 ; )
Quebec
Finally!!! Got in the 12's!
Sam : Could you please replace my time to the following :
12.984 at 106.14mph
Temperature was around 70F and kind of humid, low wind.
My 60ft was 1.899, 1/8 of 8.344 at 83.46mph
I have had a 60 ft of 1.88, but ended that run with a 13.02 at 108.28... So since my goal was the E.T., not the mph, 12.984 at 106.14 it is...
I am very happy to finally have reached my goal... Now the next goal is to go in the 12.8's... Probably in the fall, when temperature will be in the 50's, it should be very reachable. Now if ever Livernois comes with their stage 4+, I guess I could hope for 12.7's... lol, never enough right? That's what is fun about modding our cars...
Cheers all and thanks for the encouragement to get there!
steve142857
11's in '12 ; )
Quebec
Hey SHOSPAZZ92 !
BTW, happy birthday Sam! Just saw it is today by coincidence... Enjoy your day!
EcoBrick Bob
Clear Lake, IA Naples, Fl
Clarification..........
Regarding my EB Flex that is stuck at 13.064.... Tune is from Torrie @ Unleashed Tuning using SCT tuner.
"Brick" has 3-Bar Sensor, 50% W/M system, Boost-a-pump, Nesho mid-pipe, Custom CAI using a RotoFab "J" pipe & AEM filter, & 18" Conti-DW Tires/ASA wheels reducing un-sprung weight by 60+ lbs. Torrie has been continuously tuning based on SCT LiveLink Logs.
No recent runs due to HOT weather, but when it was a 91 deg - 86 deg evening, my top speeds were as high as 105.65, which is a 1.5 mph improvement over my lowest ET MPH. Several 13.1-low 13.2 runs on an obviously slow track.
Already has 25K mi.
yamahaSHO
E85 whore
Arkansas
They're doing some special street drags in Hastings this month, so I'm going to see if I can make it out there for one of them. It's 2 hours away, so... We'll see how much I feel like driving 4 hours for a couple passes.
14-second bound!
Side note: How hard is it to have a mod combine/replace a thread and sticky it?
steve142857
11's in '12 ; )
Quebec
Went to the track tonight...
3 more runs in the 12's and the conditions were not optimal :
77F, a bit humid and a strong wind directly hitting the right side of the car...
For some reasons, the trap speed on the right lane appears to be 2-3 mph slower than the left lane...
On the left lane I got 12.997 at 107.99 and 12.976 at 108.15
But my best time was on the right lane with 12.958 at 105.40 (should be around 108... the guy cannot explain, but it has been like that all season, but I can't always go on the left lane...)
So, it seems like the car is ready to go in the 12.8'ish when wind won't be a factor and when temperatures cool down.
Woohoo!
Cheers all!
P.S Thanks Sam for the update... BTW I am now running stage 4+
zach44102
BIG TURBO
Georgia
Going to the strip friday night, looks like its going to be pretty warm with lots of humidity. Hoping to get on the list.
91PDXmocha
Portland , Oregon
Figured id get this one official from long ago. Once I finish this short-block ill see what happens with all the new mods.
I was missing the tires,tuner,injectors,maf and mounts last time around.
T/C mtx 5 psi , Im 565G
yamahaSHO
E85 whore
Arkansas
While you're at it, change the two that are out of order in the boosted section...
steve142857
11's in '12 ; )
Quebec
Updated.
-Sam
Hi Sam, thank you for updating mine as well (posted three posts above a couple of days ago):
12.958 at 105.40 (should be 108, because that lane was always short of 3 mph, but doesn't matter)
Thanks a bunch Sam!
Cheers!
steve142857
11's in '12 ; )
Quebec
New record! 12.942 at 108.89 mph... Thanks Sam... Next record in about a month, when temperatures will be cooler and I will have new brakes because honestly, I don't like the noise when I brake at around 110 mph at the other end!!!
IMG 0157
gregoire
nashville, TN
1/8 mile times
Car number 2121, 1/8 mile times, Gen 4, Air raid CAI, Corsa exhaust, Livernoise stage 4:
# 1
09/89/2011 18:32:25
FULL TREE TROPHV CflR T TRIflLb 31-4-5O
2121
Class
Reaction + .9898
68 ft 2.8438
338 ft 5.6249
ET @ 594 FT — 8.0398
1/8 ET 8.6359
1/8 MPH 82.39
1.0511 1st Finish timing
09/09/2811 18:45:52
FULL TREE TROPHV COR T TRlHLb
-^ ± i # 2121
Class
Reaction + .1119
60 ft 2.0618
338 ft 5.7852
ET 1 594 FT — 8.1741
1/8 ET 8.7211
1/8 MPH 82.27
3.3248 1st Finish timing
# 18 09/09/2811 18:55:24
FULL TREE TROPHV CflR T TRIflLS
2121
.0209 Reaction + .2161
2.0119 60 ft 2.4567
5.6621 338 ft 7.1151
8.1368 — ET H 594 FT — 18.3119
8.6851 1/8 ET 11.8188
81.95 1/8 MPH 63.73
1st Finish 2.5281
if 64 ;i?9/09/281i '19s 33; 52
FULL TREETROPHV CflR T TRIflLS :Z5S»5
2121
Class
.0479 -- -- Reaction
2.1071 60 ft
5.7950 338 ft
8.2512 — ET @ 594 FT
8.7968 1/8 ET
82.60 1/8 MPH
steve142857
11's in '12 ; )
Quebec
# 1
09/89/2011 18:32:25
2121
Class
Reaction + .9898
68 ft 2.8438
338 ft 5.6249
1/8 ET 8.6359
1/8 MPH 82.39
09/09/2811 18:45:52
-^ ± i # 2121
Class
Reaction + .1119
60 ft 2.0618
338 ft 5.7852
1/8 ET 8.7211
1/8 MPH 82.27
2121
2.0119 60 ft 2.4567
81.95 1/8 MPH 63.73
1st Finish 2.5281
2121
Class
2.1071 60 ft
5.7950 338 ft
8.7968 1/8 ET
82.60 1/8 MPH
Just to be clear, you ran your best run on the 1/8 mile in 8.63 sec. at 82.39mph?
It is the first time I see odd calculations like that! 60ft, 68ft, 338ft, 594ft... bizarre... Anyways, if you did 8.63 at 82.39, my guess is that you would do the 1/4 mile in about 13.45sec. at around 107mph... what were the conditions (temp, humidity, wind, altitude)?
Good run bro!
lingyuair
