ThrillSHO
Before you run out and buy NASCAR 6-piston calipers, F1 carbon fiber rotors and 50 feet of stainless steel braided brake lines, it would be wise to take a closer look at what brakes do (and don’t do). Write this down 100 times: “Brakes do not stop the car.” Brakes convert kinetic energy (motion) into thermal energy (heat). What stops the car? TIRES! The coefficient of friction between the tires and the road. Why does it take a longer distance to stop when the road is wet or icy? It doesn’t have anything to do with rotors, calipers, pad compounds or brake fluids. It has everything to do with the coefficient of friction between the tires and the road.
So, to decrease stopping distances you really have only 2 options: 1) Press the brake pedal harder. This theory only holds up until the tires lock up. Beyond that you just get a sore leg. 2) Increase the coefficient of friction by using stickier tires or wider tires.
So, why would anyone upgrade to larger brakes?
1. If your car is heavy, with sticky tires and small rotors, you may not be able to achieve maximum deceleration or even lock up the brakes, therefore you need bigger rotors. (this is rarely the case)
2. If you are converting too much kinetic energy into thermal energy and it is warping your rotors or causing your pads to fade. You need cooling ducts and/or larger rotors.
3. You just wanna look cool (and who doesn’t?).
Bottom line: Don’t expect shorter stopping distances thru brake upgrades. The practical reason for doing it is for thermal management. True, stopping distances will be shorter if fade is reduced, but that can be achieved with race pads who’s characteristics don’t change with temperature. For all but serious track duty, 11.7” front rotors and stock rear rotors with quality cabon metallic pads are sufficient – ie 96 brake upgrade.
ThrillSHO Racing
93 ATX SHO
UDPs, LPM, 80mm MAF, K&N w/CAI Snorkle, 8mm Taylor wires, Koni Struts, High Rate Linear Springs, Camber plates, Adjustable rear control arms, Touque box brace, Poly bushings, 24mm front SB, 26mm rear SB, Alum SFB, Full-length SFCs, Front & Rear STBs, SS Y-pipe, Borla Cat-back, TransGo Shift Kit, Relocated battery, Five point harness, Five 2" gauges below the CD player, 225/45s on 16x7s
Very Low Very Fast
ThrillSHO Racing
93 ATX SHO
Very Low Very Fast
