My car has been whining since I bout it 3000 miles ago. I replaced the serp tensioner bearing but it kept whining. Today I attempted to reset the tension on the timing belt. I found my crank pulley with no colored marks only a V shaped indent and a \_/ shaped indent separated by maybe 45°. I pulled it and the lower cover anyway, the dowel pin was at about 1oclock and the belt was tight on the front. I felt the spring and it was loose, I could easily move it up and down on the tensioner. I held the tensioner with a hex key, loosened the 14mm, and edged a little tennsion off. The spring was still able to be moved up and down the same amount. Upon reassembly it still whines.
1. How do i do the reset with a pulley that does not have the colored marks?
2. Is the spring bad or am I that over tensioned?
