temp sensors
sho4life
midwest
Are there two of them? My car reads hot on freeway but normal in town. The one plug isn't hooked up under the rear manifold. Can this give a misreading?
AREA 91
PA SHO SHOP
Area 91
The sensor below the rear exhaust manifold on the driver's side of the block is the oil pressure sensor.
If you mean the sensor that is threaded into the heater hose hard line, that is for the EATC.
sho4life
midwest
Anyways why would it overheat the faster I go. Shouldn't it b the opposite? Will the low speed on fan cause this? Thermostat?
