temp guage
RiceeatingSHO
Travis R
Alabama
my temp guage has not worked since I got the SHO. When the ignition is off it floats up but then drops all the way down when pu on ACC and when cranked. What is wrong? Is it a sensor? What parts do I need?
40BelowSummer
Puerto Rico
If you are facing the driver side wheel the sensor is located in the water outlet housing as seen in the following diagram. Check the connection on it as it is a push-on connector and could be loose.
The sensor is only used for the gauge on the dash as there is a seperate ECT (engine coolant temperature) sensor for the EEC (computer).
NewPicture
pimp
Orange County NY
Sorry for the jacking, could the ect have any effect to the eatc through computer on a second gen?I just put a temp sensor in my car today, havent had any temp reading in months due to the car sitting for 4-5yrs.I used a 18mm deep socket and did it without moving anything out of the way, "no air box cone filter".It was a great feeling to see it working.
