wymjym
I'm starting to have heated discussions with a local tranny shop that rebuilt my ax4n transmission.
They delivered it with some serious drivability issues. Returned it with less. I drove it @ 50 miles and determined that the tc locked up or not but did not modulate (smooth transions between locked and not locked). I returned it and they took the tranny out, told me that they found a faulty tcc solenoid (which they had 'replaced' with the initial rebuild), replaced the inner harness and put it back together. It now shifts better but the tc lockup is still an issue. I suggested that possibly they installed the incorrect tcc solenoid. The mechanic insists that it is the correct one for the tranny (which it might be) but since the car is an early 97 model, the tranny was original to the car, the pcm had never been flashed I was dumbfounded when he told me that it speced out fine at between 13~24 ohms. I have no 1st hand experience with these things but my reading indicated that the early tcc solenoid should be .9~1.5 ohms (96~mid 97) and that should be the one in that transmission.
It is getting to the point where I'm either going to need some definitive proof that the tranny should have the .9~1.5 ohm tcc solenoid or pick the car up and pay someone else to repair it again.
Any help would be appreciated.
wj
wj
