ShineSHOpRacing,
The engine should fire on the first couple of rotations. Something is not right. Do you hear a low, rumbling sound from the fuel tank at idle? That would be the need for a fuel return line check valve. They usually extend the cranking times, but not as badly as you describe.
Your TPS could be sending a bad throttle position signal to the EEC. Do you have any problems with an unsteady idle? Dead spots or hesitation in accelerating? The IAC valve and a crudded up throttle plate could also be causing tough starting. Do you have any other unusual conditions to report?
Adam,
If your engine is turning only 600-700 rpms at idle, it sounds like you need to reset the idle program. This is required anytime the battery is disconnected. To reset the idle, disconnect the battery for 15 minutes to clean out the RAM. Reconnect the battery, start the engine and let the rpms settle for about 15 seconds. Within the first 70 seconds after starting the engine, add all the loads the engine will see at idle: shifter to "D", climate control to AUTO with temp to 60 degrees, headlights ON, press brake pedal and turn steering wheel from side to side. This will teach the EEC the range of motion needed by the IAC valve to maintain the programmed idle speed.
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
