TACH and GAS meter's!!!
sleepa
Wisconsin
alright...i got my car bout a week ago..and the night i got it...i got into my car and i started it up and the tach meter didnt work..then the next morning..i got in it again to move it and the tach meter worked that time...and it hasnt worked since....my gas gauge also doesnt work.....any suggestions??could it just be a wire or somethin??is it the float w/ the gas guage???
sleepa
Wisconsin
haha..nevermind guys...i gotter workin..it was just a fuze...she all works good now..thanks neways...l8a
sleepa
Wisconsin
ok..when i put the 20 amp fuze in..and i drove to kwik trip to get gas..and the tack and gas gauage worked about 1/2 the way there and the fuze blew out 1/2 the way there....then i put a new one in when i got gas....and it blew up before i even got outa the kwik trip driveway.....so then me and a buddy went to another town and back and when i got home i put a new fuze in it and it is still workin....wut could be the problem???is it a short in a wire or what?????
DJ SHO
NY
Sounds like a short. That's usually what trips a fuse in the first place.
ericwick19
saginaw, MI
remove your cluster and check the connections on the back, maybe there is a intermittant short right there.
Which fuse have you been replacing?
What other loads are also supposed to run off that fuse? (See your owner's manual if you have it.)
sleepa
Wisconsin
Ok..here's the deal...this is gonna sound like the weirdest thing in the world....insteada just blowing fuzes all the time i would just put it in and only turn my key 1 turn to "update" the gas guage...and 1 day i forgot to take it out and of course it blew!!haha....then a cple days later i was gettin gas again..and i put a 10 amp instead of a 20 amp in the fuze box and i forgot to take it out again and that 10 amp fuze has been working for about a week now!!!explain that 1 to me?????hahaha...weird huh!!
Hubes
Burl., MA/Chesapeake, VA
there is a fuse that does your gag gauge? my gas gauge reads full all the time. when i turn the car off the gauge drops. any suggestions?
You probably have an open circuit in the fuel sender circuit or a float that is stuck in the "full" position.
Probably a bad sender.
The guage in my 89 shows max full for 5-15 minutes after I start the car, then it goes to the correct reading (normally).
The sender unit should have a resistance of 22.5 ohms when the tank is empty and should read 145 ohms when the tank is full (per the 89 EVTM).
