URLACHER54
is any one using a 180 degree t-stat. i was told by ford not to use this one that it will interfer with the coumputer, to stay with the stock t-stat.
While the SHOtimes website may contain a great deal of good information, it also contains a great deal of generalized mis-information like the snippet that you posted above. While it's always a good idea to help maintain the proper engine coolant temperature with a properly-rated thermostat, you also have to remember that the thermostat is only one variable in the overall cooling system equation. Paul was correct when he said that the thermostat's primary job was that of regulating the minimum engine coolant temperature. Once the coolant temperature has exceed the thermostat's preset opening temperature, it then opens to divert the heat-soaked engine coolant to the proper components (or the radiator and cooling fans) to allow them to do their own job of cooling the engine coolant.Shoblu said:I got a heads up for it from SHOtimes.com. That and a lot of other good information on that site.
You want to run a thermostat thats going to keep the coolant temp within factory spec. The ECU depends on coolant temp as a major factor in determining fuel trim and spark curve. Too cool a temp and the system will run rich. Keep the temp at where it is designed to run and the radiator fan's and their thermoswitch will do their job in keeping the coolant from getting too hot.
Axianator said:That said, I can promise you that running a 180F thermostat or even an open cooling system (e.g. no thermostat at all) in your '89-'95 V6 SHO will not cause your engine to run any richer than if it were fitted with a factory-rated 192F thermostat. I might also note that while I mainly do so as a result of my local climate, I have been running a 180F thermostat for over a year now with zero problems.![]()
While I personally think that it would take some fairly cool ambient temperatures to prevent even an open cooling system from reaching operating temperature, I agree that I should have tagged my original statement with the condition that "an open cooling system will not cause your engine to run any richer than if you were utilizing a factory 192F thermostat, provided said system is capable of reaching a stabilized operating temperature above 160F."SHOck said:If this guy's SHO has, say, a two-core radiator, and he lives in the north, he could easily run into trouble getting the engine warm enough to exit cold-start mode if he were to run an open coolant system. I would not declare an open system problem-free for all.
