halfasspunk
I have been told that using synthetic oil in high milage cars can be bad, that it can actualy eat at gaskets or something like that, is this true, or is this just bs ?
Lol Paul! You beat me to it while I was writing my book. I didn't mean Horsepucky to youSHOZ123:
If your car isn't burning/leaking oil now it would be perfectly fine. In fact it would clean the motor up. If it is burning/leaking it may get expensive.
Scott, my responses:sdpatt:
Case in Point #1 - Castrol GTX 10W-30 has allowed my engine to live a healthy, happy life for 276,900 miles now without cam lobe wear.
Case in Point #2 - I have performed valve gap adjustments on SHO engines with as few as 60,000 miles that have exclusively or primarily used Mobil 1 oil thorughout their lives and found significant cam lobe wear.
Case in Point #3 - On at least three SHO engines that were using Mobil 1 oil, the engine exhibited ugly, metallic noises during and shortly after starts following long downtimes.
The one 60,000 mile engine was owned by a dedicated owner who regularly replaced the oil and filter at 3,000 mile intervals. He paid the extra cash for Mobil 1 because he wanted to use the "best" oil. He brought the car to me because he wanted to take the best care of his prized possession. He drove the car very gently by my standards. He babied the engine. He was very disappointed in my findings, but changed to Castrol GTX and said he found the engine to be noticeably quieter at startup.Markus:
2) Simply stating that you have seen low mileage Mobil 1 engines with cam wear is meaningless. How were these engines treated? How often was the oil changed? What oil filters were used? Were some of the scheduled oil changes simply forgotten? Were the engines driven extremely ******* a daily basis? In what climates were the cars used? How well did the engines warm up (very short trips in cold winter weather will not allow then engine to warm up, and we all know this is not good)? Had all required services been performed on the engines? Did the engines have an overheating/underheating problem? Had the engines been allowed to warm up before they were driven hard?
Scott, start open tracking your car and get back to me on the wear issue.sdpatt:
Case in Point #1 - Castrol GTX 10W-30 has allowed my engine to live a healthy, happy life for 276,900 miles now without cam lobe wear.[qb]
</strong>Scott, that's not science.[qb]
Scott, that's not science.Case in Point #3 - On at least three SHO engines that were using Mobil 1 oil, the engine exhibited ugly, metallic noises during and shortly after starts following long downtimes.
Yeah, 'cause you know the SHO has "special" metal from Crypton jpshakehFOR SHO:
Well i dunno about other cars, but shos should never have synthetic.
no.halfasspunk:
Okay, but I heard that after a car uses non synthetic oil for a long time, and then you switch to synthetic it can clean the seals and gaskets away, is this true?
Actually, synthetic doesn't break down... it just gets dirty.Bluto:
There is no doubt it doesn't break down as much as org.
