aberdeenSHO
ok i've been wondering why else that i would be smelling that sweet smell coming from my vents if i wasnt loosing coolant. my rad seems to be working fine. I just can't understand why my car is overheating. the gauge in the car seems to be working fine too. it slowly climbs in the normal range and when i turn the a/c on it will overheat slowly. otherwise it just fluctuates. i have the part to replace the temp sender. but why would i do that if the fan comes on when i turn on the a/c, and it comes on when the gauge hits the top of the n on normal? are there any other sensors that i'm leaving out? if i was to have the wrong temp thermostat, could that be causing my problems, because i bought it from autozone and i think it may have been a 192 instead of a 180... so but could that cause this much a problem?? anywayz i figured maybe i'd try once more at this problem on here.. maybe someone figured it out i don't know. but ok so thanks for anyone that helps out...!
