Suspension kit?
SASHO91
Zoom Zoom
San Antonio,TX
Ok guys. i was looking through midwest sho, and found their full motorcraft sus. kit. i am going to replace all of my suspension parts. and add some performance ones also. i have a few questions about this. 1)Will the motorcarft struts be able to handle cut CC, with 1.5 coils cut? 2)Does this seem like a good deal, meaning, it coming complete with all bushings and mounts? 3) For the performance, i was going to add, ALSFB's, SFC, Rear strut tower brace, 26mm rear sway bar, and a h-brace. Will this give me a fairly good performance suspension, with stock struts, but with all of the listed above? and finally were should i get all of the performance sus. stuff from? Thanksin advance, i know its alot, but hey, gotta do it though! thanks again!! :thumb:
SASHO91
Zoom Zoom
San Antonio,TX
c'mon guys, i need some input. i want to have her ready for the twisties! After the run, i have got to get some upgrades for her sus. Any input guys?
thanks!
SHOoff.
PA
OK, with your cut cargos, Tokico or Koni would be the way to go. IMO ALSFBs are only needed for a track car, I had them and heavy duty motor mounts, the whole car vibrated like my girls favorite toy. :D I replaced them with new stock ones, now I just use the HD motor mounts and a torque strap. The H-brace is also not needed unless you get better control arms.
Get the STBs, SFCs, 24/26 swaybars too, and make sure you use all poly bushings, that'll make ya happy :thumb:
Check out my sig.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
You should get somehting better then motorcraft struts if you are going to be cutting springs. I would have gotten Konis and Intax springs which is whatI have and mine handles nicely with what I have.
Jaxon
O'Fallon, MO
Why are you asking that in a suspension kit thread? Also why not just check out midwestsho.com for prices as it is on their website. Also, I would think that it would work because the tweecer has been used on many different ford models that I've seen.
Hack
Washington State
I will disagree with that. The "torque box" is just flimsy sheetmetal. I would install an H-brace even if the rest of the car were stock. In fact I ran one long before I got my TCE control arms, or saw any track time.
