Supercharged/Nitrous What?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
Dyno numbers when the tuner calls back and makes me an appointment.
93rev2sev
Hockeytown
That's still...300. Persian armies had trouble with 300 at Thermopylae. You're going to have it in a car.
A front wheel drive car...but a car.
Ishodu
Sweet work lots of have been very busy this weekend doing sweet projects. Can't wait to see this one!
E1 v2
crash tested
holiday inn
This should provide some much needed intercooling for the blower. Should help a lot.
SHO U UP
SHO Guru
Virginia Beach, VA
Looks killer James. The fuel delivery now should be where it needs to be. Can't wait to see the numbers bud. Did you retain my methanol injection or completely remove it? My only concern is air flow. The K&N cone filter was massive and sucked in a lot of air and now its back to the stock set up. I'm pretty sure you have that worked out tho too. ;)
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
I'm planning on putting the battery in the trunk, using the cone filter and plumbing the water/Meth as well. I've gotta remove the driveline to fix the belt squeal and clean up the engine compartment. We'll see how it all goes.
thatSHOguy101
