ES_8CH_OH
White '94 ATX
When attempting to operate the sunroof, I have to push the button twice to get the glass to move in any direction. When I close the sunroof from the full open position, it does not stop at the closed position on its own. Instead goes right to the vent position unless I release the button. Then it stops. The same goes for when I attempt to close it from the vent position. It does not stop by itself like it should.
A buzzing noise from the passenger side of the dash accompanies the sunroof problem. It sounds like it’s coming from behind the glove box whenever I operate the sunroof. Is there a relay back there that needs to be replaced?
I replaced the sunroof switch with a new Ford switch from Cincinnati SHO. It did not fix the problem.
What do you suggest?
