subframe recall installation
Bank of SHO
Vegas
While reinstalling the subframe, The rear drivers side nut popped loose. I was able to start the bolt into the thread, but the nut spins. I looked under the carpet, but I can't find the rubber plug. Where exactly is it, and what is the procedure to get to it. I don't even know how to peel the carpet back very far.
The recall was performed by the dealership about a year ago...or was it really?
Speedy_91_SHO
Toledo, OH
Remove the molding next to the parking brake release handle. There is one screw on the piece and remove the first screw on the door jam trim. Pull back the carpet to that point and IIRC it is up near the pedals, maybe under the brake pedal. Just peel off the rubber plug and it is right there. I had the same problem as you only on the drivers side.
Bank of SHO
Vegas
Found it. Thanks a bunch. It worked as intended once back on the tabs.
Tom
