subframe bolt
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I have never had to do it, but I am pretty sure you can use a hole saw and cut a hole in the floor right above the location. You can then bend the retaining tabs back and remove the captured nut to pull the broken bolt.
Look up "subframe recall kit" and see what that gives you.
I have a couple subframe recall kits at the shop and they include the rubber plug to put back in the hole you cut with the hole saw along with new bolts and a new backing nut.
Let me know if I can help.
Mike
MD Ever
MeanestDad Ever
South Lyon, MI
Must be the day for that...
Mine was the driver's side front. Any ideas on how to get to that?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
uh, just look at the photo you posted. There is an access hole right above it.
As for the rear subframe bolt, if you have had the subframe bolt, recall performed there are already large holes cut into the floor of the car. Pull up the carpet, pull the plugs out, and the bolts/hardware are accessible right there.
MD Ever
MeanestDad Ever
South Lyon, MI
Whats holding the nut inside the frame rail? It moves around pretty easy but won't come out.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
ive had the front break off... there is a hole and it is a BIOTCH to get out... depending on how much of the bolt is still threaded with the nut
EDIT:
There are retaining Tabs... try hammering on the bottom of the bolt... the tabs will break off... but you really dont need them... atleast i didnt... i just used a wrench through the "access hole" to hold the nut instead of the tabs since mine were broken from getting the nut and bolt out.
justin mccluske
washington
thank it took me about 20 mins to fix it i just cut a 2" hole in the floor above the broken bolt and it easly came out!
