Bizzy
- Joined
- May 1, 2001
- Messages
- 13,222
- Reaction score
- 1,462
Well, Monday's really suck just for the record. Today on my way home I took a left hand turn onto a road and felt a tremendous pop and when I went to straighten up the wheels they didn't want to work right. So I stop immediately on the side of the road and get under there to look. No broken tie rods, no broken sway bar, nothing appeared out of the ordinary at all. I shook and tugged on everything and nothing budged. So I drove very slowly about 1/2 mile to my sitter's house. Her husband is my mechanic so I felt at ease. He took a look under there and found my problem.
Now, forgive me if I don't say this right, but I'm really upset at this right now. My subframe bushing assembly & bolt pulled completely out of the unibody. My cradle is hanging down on the driver's rear corner. Good old Michigan "rust factor" as my mechanic puts it. And yes, I had the subframe bolt recall work done.
So I left my baby with him. (You all know I trust him at this point, right?) He's going to drive her in tomorrow to fix her.
This is what he plans on doing. He's going to pull the carpet out from under the clutch/brake pedals, drill a hole large enough to expose the hole where the subframe bolt goes through (there's a hollow space in there) and install a very large metal washer and bolt to hold the cradle up where it's supposed to be. Then he's going to put a piece of sheet metal back where the hole is and primer it up so it doesn't rust. He's also going to check the other side to see what condition that one is in.
Now, for all of you out there with steering problems. These are the symptoms I experienced beforehand which I mistook for something else.
When I would make a left hand turn, it felt like the wheel was catching on the inner part of the wheel well or my rack was sticking in one spot. It would "hang up" for a split second and then it would be fine. From what I understand, everthing was really out of kilter there because the bolt and nut was giving way little by little.
Oh well, tomorrow will be a brighter day....right?
<small>[ April 29, 2002, 06:39 PM: Message edited by: Bizzy ]</small>
