Sub frame bushings are they the problem in my SHO!!!
eli terry
Davenport, Ia
Recently I have noticed that I have what seems to be popping in the frame right under your feet when in hard turns up my 45 degree incline drive? I had the car up at a service company to check the bushings and they told me the bushings were good, No bolt pull through or deformation of the original bushings. Front end is good and tight all ball joints ok tie rods ok. So what the heck is this noise underfoot? Any insight would be greatly appreciated.
'94SHO
Towley rules!!
R.I.
Strut mount? swaybar bushings? bad inner tie rod end maybe? Jack that side up nice and high, see if it pops. You can get a better idea where the noise is coming from. I did this and found the pass. strut mount "popped" on the way up, and did
it when I lowered it..:oogle:
black92
Wisconsin
Has your car had a subframe bushcing recall? Its quite possable its your subframe. But check your tie rods also.
tinkerkathleen
