Stuts on 93 ATX
bbeechsho
Louisville, KY
How hard is it to replace the struts on a 93 ATX. I am having the rack done soon, should i just pay to have the struts done too?
whlav
Huntsville,Al.
If you are having your rack replaced I would advise you to go with a Gen 1 non VAPS rack. You'll end up with a much more responsive solid feeling. Struts and spring replacement usually run about $75 per corner if you are having it done. You may also find that you need strut bearings.
Neo
Wisconsin
VAPS? what is that? I have a 1993, but I've noticed that there are 2 styles of 93's inside, does that matter on the drivetrain, or is a 93 a 93, regardless of the interior?
