Stupid question on battery cable routing...
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Ok.. I got new ones, all my fluids are filled, and I'm about ready to fire this baby up. Just making sure I got my cables in the right spot before I put the battery to it.
Positive goes to the post on the starter, ontop of, or with the one in the bundle with that small starter wire, (spade terminal).
My negative, was welded to the old bolt so I replaced it with another, bonded it to one of the bolts on the housing of the starter.
Is this all correct? Also, all my grounds i can see on the frame rail I want to ground together. And also another one to the heads, and all that. Any other things I might be missing?
Also one connector i'm stumped on. Near the heater hose temp sender, there is a wide 4 pin connector, and has nothing near there. Thought this was the other extra one, next to that one by the maf. Thanks again!!
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Well I hooked it up, battery says 12 volts, but I got 0 juice anywhere.. I hear a small arc, but wonder if thats just my alarm drawing power. ? Maybe my ground is loose? What would cause that.. :(
93rev2sev
Hockeytown
That 4 pin connector you talk about is supposed to be loose...is it like a burnt orange color?
