stumbling problem
kenny4007
clayton nc
i have a 2010 sho runs perfect when cold, after getting up to operating temp, when leaving stop light under moderate to heavy acceleration will stumble and fall on it's face, if i back off the throttle and ease back into it , it will go, it is intermittent, i have changed the throttle position sensor, cleaned the throttle body, new air filter, plugs, but still having same problem
Are you getting any CEL indicators?
Rhino561
Texas
I believe I saw a YouTube video about draining the intercooler stopped another SHO from stumbling, just a thought.
kenny4007
clayton nc
mileage on your sho? check codes. could be a fuel pump control module issue, just started seeing those on the 2010-12s.
just replaced the fuel pump driver control module, same thing, i will try draining the inner cooler this weekend and see if that helps
the worst of it is if you drive it normal, you will never know that it has this stumbling problem i've drove it normal 300-mile, round trip and unless you get on it, it's fine, danest this i've ever seen
kryptto
South East, Florida
those years - up to '14 have had recalled fuel pump modules - thus why I bought a new one - fixed of course and keep the old in my trunk - for emergencies
shootinirons
