stuck heads
Ian
Toronto. Canada
have removed all head bolts but can not get the heads free. seem to be stuck. any ideas how to loosen them? thanks Ian
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I have always had the heads come off relatively easily. Just to check, you removed the fuel rails, coolant crossover tube and the coolant tube end pieces, right?
- Mike
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
To clarify easily a bit, I have a relatively SOFT 3lb dead blow hammer I use to tap the head with once I am sure all the bolts are out.
Let us know what you find.
- Mike
