ckinart
Hi all,
Not sure if this should be here or in the Electronics section, but anyway... Over the past few months, I noticed that my front passenger door lock would not always lock/unlock when I pressed the lock/unlock buttons (on either door and/or the keyless entry). I'd have to lock/unlock/lock/unlock it a few times and then the actuator would seem to "catch" and work properly. Well, now the door is locked, and the actuator won't actuate at all. I've tried unlocking the door with the key, and it won't budge. Is this likely an actuator problem, or is the lock cylinder/linkage seized up (causing the actuator to fail)? If the actuator fails in the locked position, can it keep me from unlocking the door with the key? If disconnecting the mechanical connection to the actuator would allow me to lock/unlock that door with the key as a temporary fix, I'll do that until it gets a little warmer out and I can tackle replacement of the actuator.
Any thoughts are appreciated!
<small>[ January 13, 2004, 09:54 AM: Message edited by: ckinart ]</small>
