pimp
so finally im doing the rod bearings and i found the problem, its so obvious that i hope its not the worst, 1-when i grab the cap it has slight play, that was my noise 2-how do i split the cap off?the two nuts are off and my search here doesnt say if i should pry it or what, dont know what to use cause theres no space between it. all others are real tight but im doing them all, im guessing the bearing might be totaly missing, i see the copper in the drained oil and around the pan.now what??another motor?
