cohill87
92mtx redonblk
Heys guys just seeing if anyone had experienced a similiar problem to what I am experiencing. Whenever under hard acceleration or moderate to hard cornering I get subframe pop.(my sfb's are shot this I know), also my alighnment gets severly altered, as in to go straight my steering wheel is 60 to 70 degrees out of 12 o'clock. The steering wheel only goes out of faze to the right. I have checked my strut rod bushings and they seem to be tight. Can bad strut rod recievers in the subframe cause this to happen so severly, or is it a combination of the two. My ball joints and tie rods are fine, and I replaced the struts, springs, mounts and bearings. Also when I make a sharp corner or make a u turn I get a spot were the wheel doesn't turn to full lock like it's stuck, it could be the rack but just wanted to rule out the strut rod issue first. Any input would be greatly appreciated, thank you.
