stripped intake bolt (help asap)
kurtis adum
Driver
michigan
Its one of the three bolts on top of the intake. The one near the idle air sensor. It just spins. Its a 19 mm, prolly not even the rite bolt, with my luck. But its connected to a playe that bolts down by the injector rail. I was goin to just take that off but the fuel line goes over it and i cant get the fuel lines off ccause of the intake still being on. Ummm ne help would be awesome
-kurt-
Off Road SHO
Moderator
Kurt,
Try getting a pair of vise grips on the head of the bolt. As you're untwisting the stripped bolt, lift up on the vise grips. This sometimes helps to grab some fresh aluminum, just enough to get some "traction".
Good luck.
Tom
