strange problems with my sho
yestap
Michigan
I have a 94 with a 3.2 and i love the car. But... it ha a few weird problems maby someone can help with. Fitst i am getting oil down in my spark plug holes , but for some reason the plugs dont short out??? Next my car will be running fine when randomly the tack shuts off and it the car keeps running, or the tack stops working and it backfires and stalls out. After tat it usly starts back up, but the tack almost never works after it stalls. Then othertimes when i try to start it it just dont startand i let go of the key and about 7 to 8 seconds later it just starts up but the tac don't work.
i know how crazy this all sounds and i have asked alot of people about these thing with no help. i realy want to fix this problem so if any one has any ideas or any questions i would appreaciate it alot.
twr
whoohoo
half-way there, I think.
Oil in the plug wells = you need to replace the valve cover gaskets
Funky Tach operation & stalling = you need to replace CPS and/or Cam sensor
But before doing that, pull the codes. Do a search on the forum if you don't know how.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
More then likely a cam sensor is causing your no tach, and intermittent start issue. The car is probably due for a full 60K, which can be done by following the instructions here. Like stated above, pull your codes. If your not sure how to, use this method. Also, welcome to the forum! :biggrin:
yestap
Michigan
thanks alot for the replys and the help. im gonig to get on those sugestions.it may thke a few days but i will reply back with any results. thank you
