naval-avi8or
OK I've been trying to figure out a whoop whoop whoop noise eminating from my front pass side wheel for several months. The noise is constant and while under movement above approx 20 mph. While turning right the noise reduces to near zero (as weight is shifted off the right wheel) and when turning left is more pronounced. Tires are new and have been moved around to eliminate the tire. As well I've swapped the rotor and still have the same problem.
I'm starting to lean towards the hub/bearing assembly and have one in hand to replace it already. out side of that the CV half shaft is the only other item I could think of which I have wiggled and jiggled (while installed) to check for any obvious play.
Thanks
Curtis
Thanks
Curtis
