jkichline
This is a weird one. When I pull out from a light, I can feel the rear brakes dragging. Once I drive for about 100 feet or more, it seems to go away. I thought I might have had a sticky E brake line but it seems to be intermittant without touching the e brake in between. Also, I PB blasted both brake cables and nothing changed. The e brake spring tension on the calipers seems to be good but I don't know how to tell for sure. With it being intermittant, its tough to determine. I replaced the rear brakes and rotors recently and bled the lines without any problems. It seems almost as if the fluid isn't getting sucked back into the master cylinder correctly.
