Frostbrosracing
Hey guys I need some help. I did some reading through the forums before I bought my replacement spark plugs. Because my car had right at 70K when I bought it I figured I'd replace the plugs because there was no history of them having been done yet. Here's what I bought and installed: Motorcraft Iridium SP-580 gapped at .032. I replaced the boots and the springs that contact the plugs at the same time. I'm going to replace the plugs when I go with my new tune and 3 bar MAP but am I set up correctly until then? I've seen that the gap on the colder plugs is usually set about .026. Should I be at the same gap, and if so have I lost power with my current set up? Thank you
2013 non-PP
2013 non-PP
