Stock brake hoses to PBRs?
strykr14
Michigan
I am bout to put PBRs on my 92 - will the hoses bolt on to these calipers? (Mustang PBRs)
strykr14
Michigan
Yep, Mustang GT calipers, 2004 I think - I'll have to check but I think the seller included washers and bolts. Thanks for the info.
Make sure the washers are new. They're cheap at any parts store and can leak if they're used. No point in going back in there again with parts that are so cheap and easy to find.
FWIW you can heat the washers up with a torch so they loose their temper and reuse them. I've always found it not the easiest to find them in the quantity I want.
fast Ed
Ford lover
Caledon, Ontario, CANADA!
Usually it's the 1999 - 2002 calipers, GT or Cobra, that take the fine thread banjo bolts, and then the 2003 - 2004 style went back to the coarse thread.
cheers
Ed N.
