stock amp+spkrs with aftermarket ?
SHO_Stop'r
Portland
ok i got the wire adaptor to hook up a deck and it used the large gray connector and the medium black connector. now i have teh small black one left that has like 5 wires on it. The stero works but no stock speakers. the last connecot must be the amp turn on. how do i rig the factory amp to like rca cables to plug into my deck ?????
plz help
SHO Nick
******, Cali.
Ewww..wow..just tackled this a few days ago with my friends 88 crown vic...I wasnt too succesful, but I do remember the orange for that car was the ignition switch...the red is a constant Battery power, and black is negative of corse..even tho we used the factory HU ground tho. Umm...other than that I really wouldnt know how to help you hot wiring the amp turn on...I would suggest a shop help you..im good with electronics...but a shop...well thier paid to do thier job correctly. :thumb:
caseywan
Chicago
I had that same problem no too long ago. When my mom had the car she had circuit city put in an aftermarket head unit with some kind of fancy adapter that supposedly let the system use the factory amps (which I'm not sure if they were really working or not). Well, I got the car and my speakers were going bad, so I decided to get a new system and was going to try to use the existing amps. I got the wiring scematics from a dealership, but I still couldn't figure out a thing. The factory amps are a pain to do anything with, so many wires and crap going to them that don't match up. I ended up just getting a new amp for the system. But I would have to agree with sho nick, you would be best off to go to an audio shop to look for connectors, but you still may not be powering up the amps. Good luck.
MADMIKE
Muskogee,oklahoma
Bypass everything run the hot wire from the fuse box..run all speaker wire under carpet and threw door area and also ground the deck under neeth it self..you will see the screw.
Brad kirk
