Still having a sticky brake issue
LJRuddy
Pop lock n drop
Poaceae fields
Well, today at the Nebraska SHO tech meet, I replaced my rear lines which were thought to be collapsed causing my sticky rear caliper. Keep in mind, I bought an OEM pass. rear caliper about 5,000 miles ago. I installed the Earl's SS brake lines as well as a new set of pads and a freshly turned rotor. I am still having a sticky caliper. Taking the E-brake cable off does not solve this issue. What else could be causing my problem? I am sick and tired of replacing rear pads every 3-6 thousand miles because of this. :oogle:
itwonder
VA
Check rear brake load compensator valve. Disassemble and clean. Adjust spring tension for maximum pressure on lever arm.
1993MTXSHO
Its a Taurus...
Jersey
See if the sliders on the caliper are frozen, they should move freely, sometimes they freeze up and can make the caliper all screwy:cool:
LJRuddy
Pop lock n drop
Poaceae fields
I am missing the lever that attaches from the suspension to the bias box. Also, I moved the lever that is on the box and it seems as if the spring/rod that goes into the box might be seized. How complicated is it to remove this box and clean it out?
Storm-Chaser
Shit Louis
Hence why I always wave the :bs: flag when everyone states "it's always a collapsed hose . . . ."
. . . . just like I did in this thread > In the dark here... Collpased brake lines?
With a set of flare nut wrenches and about thirty minutes of trouble-shooting, you can usually isolate where in the system the problem is occurring . . . .
:burnout:
LJRuddy
Pop lock n drop
Poaceae fields
:burnout:
Either way, I had a set of SS brake lines that needed to be installed. This was just an excuse to put them on. :salute:
Brakes, to me, are a bitch to work on. Every single car I have owned has had some sort of brake issue that I could never fix no matter what I do. Quite frankly, I am beginning to become scared of doing a brake job because it seems that whenever I lay a finger on a brake component, something breaks in the system. :oogle:
jthod
Mr. Goodwrench
Lincoln, Nebraska
:blah::blah:
:blah::blah:
Make that an hour and thiry minutes with the rust factor.
p.s. I never did find that 9/11 mm flare nut wrench in the garage. :shrug It'll come up somewhere.
bmytych
