Emerald94
My clutch pedal is very stiff when pushed while the engine is off. It seems to get better once the engine is running but also noticed that it makes a click at the end of the push once in a while.
sdpatt:
The pressure plate is part of the clutch and the throwout bearing is only an additional $31. I recommend the SHO NUT clutch kit with wear parts. The flywheel should also be resurfaced with the proper lathe. I have found that NAPA has been equipping their stores with a dedicated $10,000 flywheel lathe and will cut a beautiful surface on the flywheel for $25.
You can always get a Fidanza flywheel!Emerald94:
I'm looking at getting everything I need from SHONUT.
My flywheel has been machined once. Can it be machined one more time?
