F-22 Raptor SHO
This is one of those "I know cause before I know what the problem is"
I just painted a spare intake I purchased over this past week (they look good BTW) and was assembling it in my living room when I noticed something that may be a problem later: my rear butterflies seem sticky. They close ok by hand, but they dont snap all the way open like the other secondaries do, rather they just ease their way open (like either there is paint on a moving part, or the spring is weak). This would affect my secondaries above 4 grand opening as efficiently as they could. Now I know vacuum holds these closed until 4000 when the vacuum is removed and the butterflies snap open under spring tension. Dont know if the air pressure would force them open any quicker than the spring tension, or if the engine relies totally on the spring tension to snap the butterflies open.
Here are some observations:
1: I dont think there is any paint on the moving parts as I was careful to tape them off. I am going to take the actuator arm off tonight and see if the butterflies behave differently.
2: The 2 holes on the diaphram (one underneath and one on the ******) are not plugged, at least not on the outside.
3: I cleaned the butterflies with Berrymans prior to painting and just lubbed the butterfly shafts with some Pb blaster to see if that helped...it didnt.
Question: anyone ever have this happen before? I dont even know if this will be an issue, but if the car doesnt run perfectly later (or seems sluggish as it goes past 4000 rpm), that this could be the cause.
Thoughts?
Thoughts?
