bubba
ATX Connoisseur
I looking for the thread pitch for removing the steering so I can remove it and put a new wheel on it
Tick Tock Tick Tock. Come on guys.....I mean removing and installing a dash is only like a 30 min job.
That was sarcasm if you didnt pick it up. Good luck.....glad its not me, I REALLY dont like interior work.
You don't need a puller for the wheel...
Remove bolt.
Grab wheel at 3 and 9.
Pull backwards on it while rocking each side forward and backward (basically like trying to wiggle the wheel off, except using more muscle).
The wheel will be really tight and hard to move, but it will loosen up and slide off.
I've probably done 7 or 8 Ford wheels this way, it works for me.
Remove bolt.
Protip:
Don't take the nut off. Just unscrew about 1/8" from the wheel, but leave it on the column. That way when the wheel breaks loose, you won't smash yourself in the face with it from pulling on it. Don't ask me how I found that one out...![]()
