Steering wheel replacement options
Tactical SHO
Bit Late the the SHO
Lodi ohio
I have a 95 SHO and want to replace the factory steering wheel with a racing steering wheel. I want to do the Ford racing steering wheel Style or go with a Momo or something like that set up I have not seen anyone change their steering wheel is this possible. Thanks
sperold
Last to Know
Biggest issue will be the airbag.
You will have an airbag light flashing till the end of time.
Very often, these wheels do a poor job of fitting nicely on the steering column. The airbag clock spring takes up some room and is hidden under the standard wheel column skirt. Chances are, you new wheel won't have a skirt to hide the space.
