depends how bad it is out of alignment, 1 degree off is like dragging your tires sideways for 26' every mile you drive I do believe - read that on tirerack.com, 1 degree off is a lot though.
the bad thing is, it will shape the tire a particular way, say you had the alignment off real bad, drove it for a couple weeks, then had it aligned after the tires started to wear, they will continue to wear in that pattern despite how the alignment currently is.......
alignments aren't THAT picky, you more or less want the general setup and have matched trends... slight caster lead on the right side, negative camber on both sides, toe in on both sides.......
if the LF is -1.5 degrees negative camber and the RF is -1.7 degrees camber, this is not nessecarily a bad thing.... you probably will never notice, in fact I'd bet a large sum of money you won't.
an Ideal setup for a SHO depends on how much caster you can get out of it.
-1 to -2 degrees negative camber
4 degrees caster left side
4.5 degrees caster right side
somewhere from .05-.10 toe in on the front
I think on my rears right now I'm at -1 degree negative camber and .15 degree of toe in... I set the fronts to toe out just for the **** of it recently to feel the difference, i think I'm out -.05 toe out right now, I hear a lil more tire squeal it seems through corners so I'm gonna bring that back to toe in specs...(the factory wants toe out on front)
I always try to get a half a degree more caster on the right if I'm adjusting everything from scratch, if its equal though I don't loose sleep over it. I just try to stay away from more caster on the LH side then the RH because of the road crown....
also you want the cambers to be the same, you don't want positive camber on one side and negative camber on the other side, this will cause a pull.....
yeah I do alignments a lot, I'm the only one in my shop who does them. I can do a 4 wheel toe set on most cars in under 15 minutes from the time it hits the lift to the time I take it out on a test drive...... I get in the zone and can do 3 alignments an hour when things go good and I don't need to do a lot of tweaking....
