Steering "rock"
SHOfun 93
Euless, Tx (Fort Worth)
My 95 has a problem where it begins to "walk" back and forth when it gets to speed. Between 50-70 mph, the car begins to drift from the right and to the left. I have surmised a few possible culprits....lemme know what you guys think.
1) Vaps
2) VSS
3) Subframe Bushings
4) Rack and Pinion
I have ruled out the subframe bushings, and retightened them with no luck on the solution of the problem.
Lemme know what you guys think. rant
Mr Anonymous
Tire Wall
Could be tires/balance, alignment, or tie rods/ends. Even bad tie rods and ends can appear visually OK.
Did you get it off the ground and check for play at the wheels? Is everything balanced and aligned?
pjtoledo
'ol man in the SHO
toledo,ohio,usa
SHOfun 93:
Ah,, you should keep at least one hand on the wheel?
Perry :)
<small>[ September 03, 2003, 12:02 AM: Message edited by: pjtoledo ]</small>
SHOfun 93
Okay..I am going to get the 95 realigned and checked out by a friend of mine that owns an alignment shop here in Midland. Will give me an honest opinion. pizza
