steering rack
sccasho
kenova, wv
was just wondring how hard it is to replace the steering rack on 93 atx. when i go aound curves to the left , it feels like the steering locks for a second then it breaks free. i figured it was time for a new steering rack. and was wondering if the new rack would tighten up sloppy steering?
thanks for listening to my problems thumb
sccasho
kenova, wv
i appologize for this post, i posted it and then went to the search function and found much info, so my deepest appology for this next time i will search first. headbang headbang
SHOMurph
Ford B@stard
Arlington, TX
headbang is right on replacing the rack. Unless you want to dedicate a whole weekend to replace the rack I would get quotes from some shops.
Its a major PITA!!!
sccasho
kenova, wv
so i have noticed from other posts, but it seems that all the shops in my area almost refuse to do any work on any of my cars so i end up doing it myself. What would be a good price to have this done on a 93 atx i assumed it has the vpsor whatever assists the steering :)
projectSHO89
SHOless In St L
It's not a pleasant job, but it's doable.
Drop the rear of the subframe a few inches to make the job easier.
Steve
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Better further diagnose your problem first. Just put both front wheels on a couple of steel plates with some grease between them. Run the steering wheel back and forth to determine whats wrong. Remove the tie rod ends,,one at a time,, to find out if a balljoint or strut bearing may be your problem.
You can put almost anything under the wheels for this test, just put grease in the "sandwich". Better than grinding you tires into the pavement.
Perry
