aaronsbiza
95 ATX 84K, About a month ago I had discovered a small coolant leak from the waterpump. I continued to drive with the leaking pump. This morning when I was driving to work I turned the defrost on and steam just poured out. It filled the entire cabin, stunk of coolant, and fogged my windows up horribly. I turned the temp to 60 and the steam stopped. I stopped the car and had to wipe down the windows with a paper towel. I noticed that even with the defrost blasting at 60, there is still a small amount of steam lightly rolling out of the vent; as if it was not in the stream of cold air already flowing out of the vent. I also noticed that the steam only smelled like coolant when it first came out, there after it was odorless. Any suggestions? Maybe an alternative problem that doesn't involve ripping out the dash.
hail I pray to the hail SHO gods hail thout not be thy heater core headbang .
