Starting system failure
markathome
2010 SHO
VA
Yesterday I hit the start button and noticed it didn't start. Thought it was odd and maybe I just hit the button too quick. Pushed it again and it started, no problem.
Later in the day, I hit the start button and it didn't start. The starter engaged, but didn't seem long enough. I pushed the button again and it started, but displayed on the dash " Starting System Failure".
Anyone seen this before? Maybe starter is going bad? Thoughts?
Mark
2010 SHO
Sent from my SM-G960U using Tapatalk
bpd1151
Lurking Around
SHOcago 'Burbs
1st that I've read of it.
Least in the manner which you've described.
Please let the community know what, if anything at all, was the resolution for this hit/miss phenomenon.
Could be an issue with the pushbutton switch, or a battery starting to fail. But really I think it might be the starter beginning to go. Not something that happens frequently, but hot weather will definitely put the hurt on it.
markathome
2010 SHO
VA
So far so good today.
But let's see what happens this afternoon when our heat index his 105 again her in VA.
Johnbigdog
michigain
I would have someone pull DTCs. Starting system failure can mean the car tried to crank the engine, but no RPM was detected.
We did have one reported case at least where the battery case cracked, leaked acid onto the cables, ate them away over time, causing all kinds of electrical issues. But this seems restricted to the starting function.
markathome
2010 SHO
VA
Solved
Weak key fob battery! Guess it couldn't decide if the fob was there or not.
