brandon_89sho
Ok here's my problem.
A week ago I changed my battery terminals and starter selnoid..ran good for exactly a week...then
I went to a store shutoff my car then 1min later went to start it it cranked then didn't start so I turned the key off but starter kept cranking without key in it. Then stopped."deadbattery".
Went to jump started cranking as soon as the cable touched car started up but starter was still cranking drove it 100 feet it shutoff towed it home.then changed starter , starter selnoid, battery terminals and ignition lock cylinder..
I have no power to the whole car except the starter it will crank now only when jumper cables are hooked to it.
1 fuse melted it was the bottom fuse in the fuse box it sits in horizonally. Replaced it still no power.
My car is a 89 sho
My car is a 89 sho
