starter stuck on
ffemtcurrence
Clutch
Sterling, VA
ever since the cold weather has been here...when i start my car up in the morning my starter stays on....even when i pull my key out of the ignition the starter wont stop running...so usually i have to open my hood and disconnect the battery to make it stop..that doesnt always help....its only on the cold days from 50 and below...so now im jumping the car in 2nd when its really cold out and of coarse the starter cant stick then...and as long my engine is warm i wont have any probs with the starter i can start the car regularly...do i need a new starter or relay or what??? its driving me crazy :nut:
Off Road SHO
Moderator
It's probably the solenoid that sends the power to the starter motor, not the starter itself.
Tom
SHOspazz92
Banned
Triad Area, North Carolina.
Yup, My 92 did the same thing when I installed my Y-Pipe. I must have accidently banged the Y-Pipe in to the starter because when I tried to crank it over the starter went nuts. I disconnected the battery and reconnected it, Same thing. So...I let the car sit over night, Same thing. I eventually got ****** and nailed it as hard as I could with a rubber mallet. Reconnected the battery and all was fine. However after that the starter was not working properly as I probaby busted up somthing in there...It would start...Would just take a few tries. Moral of the story? Replacing the starter is a far better alternitive then hitting it with a mallet.
-Sam
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Take it somewhere to someone who rebuilds them. Could just need brushes, and a cleaning. My truck is notorious for eating starters, and the spring in mine gets clogged after time, and does the same thing.
I WOULD NOT sugguest you do this with the SHO, but in my truck when it does it, I'll put it in 5th and stand on the brake and **** the motor. Usually you'll hear it click back into place when you let off the brake.. not good on the tranny tho.. lol Why I said not to do it in your SHO
AREA 91
PA SHO SHOP
Area 91
The solenoid took a crap on me in Las Vegas. This was on the way home from the Cali SHO Convention. It's exciting, isn't it.:oogle:
ffemtcurrence
Clutch
Sterling, VA
well how bout that isnt that something...ok cool thanks for the help guys...earlier today i found out one of my motor mounts is broken i just dont know which one yet...i turn the steering wheel and the whole engine moves...man am i ever gunna catch up on the maintenance on this thing
AREA 91
PA SHO SHOP
Area 91
If the engine is moving when you turn the steering wheel, it's the SFB's.;)
Off Road SHO
Moderator
SFB= sub frame bushings. They are the rubber doughnuts that are sandwiched in between the engine sub frame and the car's "frame".
Tom
SeanMc
NoMoSHO
Whatever you do, don't get an Autozone starter. I went through 4 in 2 years. Last one did the same thing yours is doing.
n8rsk8r
Hey Where's my post?
Olathe, Kansas
Had one stick open on my mustang one time, was weird. Thought I was going to catch my car on fire :oogle:
hypnotic
Palm Bay, FL
I hate it when they stay on. It ****** me off for sure. And mine was a brand new starter that it happened to.
ffemtcurrence
Clutch
Sterling, VA
man when its warm it doesnt do it...i now park on a hill and pop the clutch in 2nd to start it, no probs then....well i cant do that rite now im trying to fix my front motor mount...like i said before mine will keep running until it gets warm and quits and then i can start it up as normal...good grief...starters
