Stalling Problems /ce Light
RAYJAY
WHO ME ?
UNION DALE PA
Ok on my 1993 having a couple of problem, see what every one else thinks ...
was getting ce light with codes
10
111
172
changed both o2 sensors
now I'm getting codes with light coming on and off while driving
10
111
172
173
also getting a stalling issue when I come to a complete stop / max the power steering at stops
any Idea's ???? EGR problems may be
Jeff
93rev2sev
Hockeytown
This could also be a bad/clogged IAC. Idle air control. If it gets gummed up then the car will idle poorly...or idle low.
These cars idle with the throttle body completely closed. Idle is controlld by @ 3/4" hole in the throttle body that runs to a valve...the AIC. If the AIC is tired or clogged and cannot move through it's whole range, I can imagine the exact problems you are having.
ohfosho
ontario SHOwner
ontario, canada
you made sure you plugged in the O2 sensors after installing right?
it might be a good idea to clean up everything, and do a tune up if that isnt the case. but start by resetting the computer and driving then re checking the codes.
RAYJAY
WHO ME ?
UNION DALE PA
Full upper 60 k was done new motorcraft plugs, ac wire set, clean the snakes& intake maf was cleaned tb was cleaned and yes the o2 sensor is plugged in.
I'm going to check that harness because I can't get the oil light to work the o2 oil light wire and speed sensor are all in that harness
Jeff
