Stabilizer bar bushings replacing issue
EugeneSchreiber
Kyiv, Ukraine
Hi! Need little help with stabilizer bar bushings to replace in 1992 Taurus SHO. Thing is, it seems there was different diameters of stabilizer bars, because in RocAuto shop I found options from "Rear To Frame; w/ 18 mm (23/32") bar" up to "Rear To Frame; 25 mm to 26 mm Sway Bar Diameter". Same story with front bushings: from "Front To Frame; 19 mm Sway Bar Diameter" to "Front To Frame; w/ 24 mm (15/16") Bar". I guess I can just measure diameter on a car's bar, but may be there is any other way to understand what's what?
Thanks.
itwonder
VA
According to my records, on our 1992 SHO we used Energy Suspension 9.5160G (or 9.5160R) poly bushings for the front, substituting a 90 degree grease fitting for the straight fittings that come on them. For the rear, we used 23 mm poly bushings from SHO Source. These are high quality parts; I am wary of rubber stuff from Rockauto unless it's AC Delco or Moog because I've found the Chinese made stuff to dry out and fail quickly.
