hawkeye18
Sorta cares
Hi guys, I installed SS lines on all four corners today, and I have a few resultant questions.
1.) I, like an idiot, let the MC go dry during the process. So I know that I have massive amounts of air in my system that will take a while to get bled out. I've already, er, "bled" my ABS system, and had a **** of a time doing it
, but how do I bleed the MC? Is there a bleeder bolt just like on the calipers?
2.) so, as a result of 1.), my brake pedal is spongy as all ****. Thing is, there's a spongy part, then it gets stiff again, and if I press past that, it gets weird. The car feels like it's pulling to the left, but the steering wheel goes to the right. The car actually tracks true, except when it actually stops, then it tries to pull to the right a little. I didn't do anything to the fronts except replace the calipers, brackets, and lines (and rotors too, 11.6" upgrade FTW). What did I do wrong?
3.) So I also installed some Tokicos and Eibachs in the rear that I've had laying around for years now and I can't get one of the top strut mount nuts on at the left side due to interference with the seat belt anchor. Is that terribly bad for a day or so? I mean, I know I can't let it be like that forever or I'll tear the mount apart, but is it dangerous to drive? Maybe that's why it's pulling left/right/whatever! :laugh_ti:
Ahh, but seriously, does anybody have any ideas? A million internets to ye who do!
, but how do I bleed the MC? Is there a bleeder bolt just like on the calipers?2.) so, as a result of 1.), my brake pedal is spongy as all ****. Thing is, there's a spongy part, then it gets stiff again, and if I press past that, it gets weird. The car feels like it's pulling to the left, but the steering wheel goes to the right. The car actually tracks true, except when it actually stops, then it tries to pull to the right a little. I didn't do anything to the fronts except replace the calipers, brackets, and lines (and rotors too, 11.6" upgrade FTW). What did I do wrong?
. The shipyard where I work has a 5-acre gravel field for a parking lot which is empty on Saturday afternoons and I've heard it said on this forum repeatedly that the easiest way to get air out of the ABS is to activate it, and I probably had it running a good 10 seconds at least. I worked the **** out of it. But hey, at least it works!
