Squeaky sunroof
Redbull14
for all of you noise trackers out there: I have a 2013 sho. There is a squeaking noise coming from the sunroof area while driving. If I hold the sunroof slide button to make the sunroof close the noise stops, even though the sunroof is already fully closed. It's like the sunroof needs slightly more pressure on it when closed to keep it from squeaking? I know the sound is coming from the sunroof because it completely stops when I open the sunroof.
Am I all wet? (no pun intended since I'm talking about a sunroof ;)
Any thoughts? Ideas to fixes?
RichInMich
Michigan
Mine does this also - haven't investigated yet where exactly it's coming from, but I attributed it to the fact that my sunroof drain lines were replaced shortly after I took delivery of the car, so I figured the dealer didn't totally bolt things back down when they reassembled it.
