ThrillSHO
Anybody know what the stock spring rates are? I'm doing some suspension geometry and wheel rate calcs and would like to compare them to the stock rates. Based on the stock wire diameter, coil diameter and number of active coils, I have calculated the stock rates as approximately 200lb/in in front and 150lb/in in rear. This seems low. I expected around 300 front, and 200 rear.
Anybody know?
ThrillSHO Racing
93 ATX SHO
UDPs, LPM, 80mm MAF, K&N w/CAI Snorkle, 8mm Taylor wires, Koni Struts, High Rate Linear Springs, Camber plates, Adjustable rear control arms, Touque box brace, Poly bushings, 24mm front SB, 26mm rear SB, Alum SFB, Full-length SFCs, Front & Rear STBs, SS Y-pipe, Borla Cat-back, TransGo Shift Kit, Relocated battery, Five point harness, Five 2" gauges below the CD player, 225/45s on 16x7s
Very Low Very Fast
Anybody know?
ThrillSHO Racing
93 ATX SHO
Very Low Very Fast
